Update, well ok now I know why I didn't recall seeing the connectors coming off the main harness. The previous owner already joined them, so the TORS were already bypassed. So my problem still existed. Popping and farting over 3000 rpms. Let off the throttle and it smooths out. Can ride around yard as long as you don't go over 3000 rpms. But thats boring. Ok so I tinkered for a few minutes and let sit and moved on to Phazer number two, which wouldn't start. Well at least it didn't. Pulled out of barn, pulled handle twice and she fired up, but was way too high idle, so shut down. Adjusted idle screw and restarted. Again too high, shut down and adjusted, restarted but now only running on one cyl. Anyone have suggestion where to start?
Ok so back to Phazer one. Started it and let warm up 5-7 minutes. Drove around the yard for 10-15 minutes no problems, even pulled front end off the ground. So I'm chaulking this one up to bad gas..??? maybe!!
