94 Vmax 600 w/M-10 susp.?? - Snowmobile Forum: Your #1 Snowmobile Forum
Old 12-27-2012, 04:24 PM   #1 (permalink)
I recently purchased a 94 vmax with a M-10 susp. Low miles. It seems like it is very tippy , since it sits up way higher than stock. Is there any remedies. Front tss shocks might need rebuilt? I thought of replacing skid with one from my 97 vmax, pro-action. Any thoughts
94 Vmax 600 w/M-10 susp.??-skid.jpg
tlaroy is offline   Reply With Quote
Old 12-27-2012, 06:31 PM   #2 (permalink)
zero experience with the m-10's, but from the angle in the picture it does look a bit jacked up at the rear. would almost think you would have excessive ski pressure.
you may consider playing with the suspension adjustments a bit before tossing it under the bus. as for the fitment on the 97 and up skids, they are narrower than the tunnel. not a big deal, you will just need spacers at the mount locations.
Old 12-27-2012, 07:49 PM   #3 (permalink)
Here is some fine tuning information I found when I put in my M-10. Hopefully this will help.
Fine Tuning The FAST M-10 Suspension - SledNutZ
dieselcamper01 is offline   Reply With Quote
Old 12-27-2012, 10:42 PM   #4 (permalink)
smokingcrater's Avatar
That isn't mounted correctly... The approach angle is INSANE, and I'd guess the ski pressure is way off also.
3) 2004 Yamaha Warrior
4) 2006 Yamaha Nytro
Old 12-29-2012, 02:52 PM   #5 (permalink)
Previous owner had a dealer install it. Where can I find the measurements for mounts?
Old 01-01-2013, 12:53 AM   #6 (permalink)
Here is a better pic, looked over the tuning from above post, every thing looks setup right. Had a chance to ride it about 50 miles. It rode great, in fresh snow, fish tailed a lot on hard packed road. Has very few studs down middle and half are worn to lug height. Is the fishtailing caused by ski pressure??or the studs?
94 Vmax 600 w/M-10 susp.??-image.jpg
Old 01-01-2013, 05:19 AM   #7 (permalink)
Ski pressure, give a slight increase to the front of the skid shock preload to take a little weight off the skis.
Old 01-01-2013, 08:42 AM   #8 (permalink)
vmax's normally sit basically level, so with yours tipped so far forwards you are going to have all kinds of weird handling going on. Yep, either reduce the amount of pressure on the rear, or increase the amount on the front of the skid.
Old 01-01-2013, 09:28 AM   #9 (permalink)
Thanks for the replies, Will try to reduce rear shock pressure.
