help me please - Snowmobile Forum: Your #1 Snowmobile Forum
Old 12-21-2012, 02:41 PM   #1 (permalink)
Exclamation help me please
ok so i have a 84 i think yamaha excel III and it has the pull start and electric start but it wont start with the pull start is it because i need the key to pull start it and a battery or what cause i dont know where the key is please help me....
blank6789 is offline   Reply With Quote
Old 12-21-2012, 02:43 PM   #2 (permalink)
im not 100% but im almost posotive you need the key my old mountain mac wasnt electric start but i still needed a key to start it
Boondocker724 is offline   Reply With Quote
Old 12-21-2012, 02:44 PM   #3 (permalink)
mountain max*
Old 12-21-2012, 02:45 PM   #4 (permalink)
ok i just have no clue where its at do you know if there is a way to get a new key for it or what
Old 12-21-2012, 02:47 PM   #5 (permalink)
the only thing i could think of would be to find one that doesnt run pr whatever and take the ignition key and everything from it and put it on yours not sure if it will work but should
Old 12-21-2012, 02:48 PM   #6 (permalink)
ok thanks
Old 12-21-2012, 02:48 PM   #7 (permalink)
anytime
Old 12-21-2012, 03:31 PM   #8 (permalink)
joshkidner's Avatar
Originally Posted by blank6789 View Post
ok thanks
You can usually get stabdardized keys for these. Look it up on ebay i can almost guarentee it will fit. I could modify a screwdriver to start my indy if i wanted too. As a matter of fact yamaha prob used all of the same keys in their sleds back in the 80's. And yes you do need a key but you can either disconect the wires and keep them seperate or touch them together (one will be off and the other will be on depending on how the system works) and try starting it!
Old 12-21-2012, 04:51 PM   #9 (permalink)
unplug the connector for the switch and use the kill button until you either get a new key or new switch. unfortunately yamaha keys arent interchangable from sled to sled.
Old 12-21-2012, 05:32 PM   #10 (permalink)
joshkidner's Avatar
I thought they were. Our toro snowblower key fits in the keyhole of my sled no problem. That doesnt exactly mean i should use it.... Are yamaha ignitions in the 80s just 2 prong? Or was the estart in with the switch rather than on a button??
