1994 V-Max wont start - Snowmobile Forum: Your #1 Snowmobile Forum
Old 12-16-2012, 08:57 AM   #1 (permalink)
We've tryed everything. Choke on 10 seconds worth of cranking then choke off 10 seconds of cranking. and nothing. 10 pulls with choke on 10 pulls with choke off nothing. Put new plugs in it nothing.... Had the gas draned before it was put up so we put in fresh gas and nothing. Held throttle wide open while cranking and nothing....
Thoughts? Haven't tried ether or any of those methods yet. Thinking it might need a carb cleaning.
Cable810 is offline   Reply With Quote
Old 12-16-2012, 11:14 AM   #2 (permalink)
smokingcrater's Avatar
Cleaning the carbs every season is pretty much mandatory. I'd bet the idle jet has a tiny bit of crud in it, which is more than enough to keep it from starting.
3) 2004 Yamaha Warrior
4) 2006 Yamaha Nytro
Old 12-16-2012, 01:04 PM   #3 (permalink)
start with the basics.
is there spark?
is there fuel getting to the cylinders(plugs wet)?
more than likely carb related. skip the starting fluid, pour a bit of gas down the spark plug holes(if you have spark) and see if it lights.
Old 12-16-2012, 01:57 PM   #4 (permalink)
yes getting spark and yes they are wet.
Old 12-16-2012, 02:24 PM   #5 (permalink)
AH HA LIFE at last!!! Gas in the cylinders worked!! Thanks!!
Old 12-16-2012, 06:00 PM   #6 (permalink)
well that was easy!
be sure and verify its running properly. not a bad idea to check the cleanliness of the carbs. something made it hard to draw fuel and burndowns are costly!
