1999 vmax 600 - Snowmobile Forum: Your #1 Snowmobile Forum
Old 12-09-2012, 12:53 PM   #1 (permalink)
fryedaddy's Avatar
1999 vmax 600
stared sled it pops and runs funky have to choke it to keep it running
things done new gas good comprestion plugs good have spark
any idias
fryedaddy is offline   Reply With Quote
Old 12-09-2012, 12:53 PM   #2 (permalink)
Kemo's Avatar
how are the carbs?
Kemo is offline   Reply With Quote
Old 12-09-2012, 12:56 PM   #3 (permalink)
fryedaddy's Avatar
cleaned them they were dirty have not run sled i three years
Old 12-09-2012, 01:06 PM   #4 (permalink)
So, is it running right now?
Old 12-09-2012, 01:21 PM   #5 (permalink)
fryedaddy's Avatar
no what could it be any idas
Old 12-09-2012, 01:29 PM   #6 (permalink)
When you cleaned them, did you floss the pilot jets?
Having to keep the choke on points to plugged pilot jets.
Old 12-09-2012, 03:24 PM   #7 (permalink)
fryedaddy's Avatar
yes flost them all it starts and ideles good when i hit the thodel i have to choke or it dies and back fires
Old 12-09-2012, 03:27 PM   #8 (permalink)
fryedaddy's Avatar
allmost like cilender arent firing the way sould
Old 12-09-2012, 03:31 PM   #9 (permalink)
Vintage Sled Pilot
ExciterRob's Avatar
You say it idles fine but it bogs at throttle increase. Have checked your main jets for a clog? Does your sled have T.O.R.S? If so, I would check to see if it is working properly.
'98 Polaris Indy 500 (New Ride)
'87 Yamaha Bravo (Now in KCCats Family)
'78 Polaris TXL-340 (Always in progress)
'89 A/C Eltgre' EXT 530 (My Sled... Now sold )
'73 A/C Cheetah 440 (Now w/ my Nephew)
'90 A/C Prowler w/ '96 580 skid (My oldest boys ride)
Jack of all trades, Master of one!
ExciterRob is offline   Reply With Quote
Old 12-09-2012, 03:35 PM   #10 (permalink)
fryedaddy's Avatar
what is t.o.r.s
Old 12-09-2012, 03:44 PM   #11 (permalink)
Vintage Sled Pilot
ExciterRob's Avatar
what is t.o.r.s
T.O.R.S. is the throttle over ride system. I believe that your year of Yammi will have it. Check to see if you have wires going to the side of your carbs. If you do, than your have this system. It is supposed to lower the rpms below clutch engagement in the event that one of the carbs sticks open or if the throttle lever is released and the carbs stay open. If they are not functioning properly, this may lead to your inability to rev the engine. If you go to the yamaha forum and look at the "sticky" threads, I believe there is atutorial on how to test the system and another one showing you how to bypass the system. I hope this is helpful. And if all else fails, ask "Yamadad" for some help. He is a HUGE wealth of Yamaha knowledge.
Old 12-09-2012, 04:07 PM   #12 (permalink)
fryedaddy's Avatar
thank you i think thats what its doing
Old 12-09-2012, 04:28 PM   #13 (permalink)
fryedaddy's Avatar
can i elimenate t.o.r.s if so how
Old 12-09-2012, 05:01 PM   #14 (permalink)
Vintage Sled Pilot
ExciterRob's Avatar
Yes it can be done. You can search it on youtube and I do believe that there is a "how to" video in the "sticky" threads on the top of the Yamaha forum. Good luck, that tors can be a real pain in the A$$!
Old 12-09-2012, 05:11 PM   #15 (permalink)
Vintage Sled Pilot
ExciterRob's Avatar
Here is the link to the youtube tutorial
Old 12-09-2012, 06:44 PM   #16 (permalink)
you may need to redescribe your issue. flipping the choke lever if the tors is activating wont change the tors. based on your description, you have other problems, like the carbs werent thoroughly cleaned.
worth the effort to simply unplug the wires from the carbs and plug the harness side wires into themselves(carb side doesnt care) just to rule it out. its quick and free.
from there, some better info should lead to a better diagnosis. using the choke to keep it running usually indicates dirty carbs.
Old 12-09-2012, 07:05 PM   #17 (permalink)
Vintage Sled Pilot
ExciterRob's Avatar
Sorry guys, I guess i glassed over the choke comment. I would defer to Yamadad4 as he is probably correct in that the carbs are probably still dirty.
Old 12-09-2012, 09:38 PM   #18 (permalink)
fryedaddy's Avatar
good news got the sled running good not sure if i got the t.o.r.s to reset or
blow out what ever was in the carb
heres the whole stoy on the sled it not mine its my buddys three years ago
he blow the left rings exsaust side 3/16 gouge in the jug above the exsaust
port we put in new jug and up dated pistons and rings 200 miles later it
did the same thing sled sat for 3 seasons i found him a engine from a 1998
when taking out the 1997 engine i found the both bolts were broke
on the moter mount on front primarey side so now that every thing is together right do you think the bolts that where broke could have something to do with the the motor blowing sorry i cant spell lol
ps. as for me i ride polaris now
not that i dont like yamaha 17 year of working on them more than riding them changed me over
