1990 Phazer 2 exhaust - Snowmobile Forum: Your #1 Snowmobile Forum
Old 11-15-2012, 10:19 AM   #1 (permalink)
My exhaust rusted away and I was able to find a psi after market for $25. Here in MN im riding in 900 to 1100 ft of elevation and mostly trail riding. So the ? is will I need to make any adjustments to carbs or clutchs ?
Thanks
NINETOE is offline   Reply With Quote
Old 11-15-2012, 03:11 PM   #2 (permalink)
You will likely have to rejet! Start off going atleast a coupla main jet sizes up and also raise the needle(lower the clip)!
Old 11-15-2012, 07:17 PM   #3 (permalink)
start by upping the mains 2 sizes. no needles to adjust on the butterfly carbs, i always upped the pilot.
you will know if you need to make any clutching alterations if you watch your rpms. depending on if you have the 8VO or the 89F weights, there are a few adjustments.
Old 11-16-2012, 07:56 AM   #4 (permalink)
OK , well thanks for the info. Much appreciated !
