Old 02-27-2005, 04:44 PM   #1 (permalink)
maje1999
recently bought ecxiter II few bugs in it need advice
hi i'm new here been browsing these forums for awhile, but just registerd... any way here are my issues with this sled 1991 exciter II 570 l/c when i get it starded it bogs until about 2 thousand rpm then it takes off like a raped ape was wondering if i need to adjust the carbs or what not ( by they way the sled sat for 2 years not covered or anything checked all the normal stuff ie: gas was empty ,,all the places mice could have built nests and such no nests anywhere ) and my second ??? is the primary clutch sticks abit was sticking full on for a bit would kill the motor if i hit the brakes now i wd 40 everything in the clutch cams rollers slide shaft that seemed to help a little been doing it for like 2 hours now got it to release but like like it should when it comes back it goes all but about the last 1/2 to an inch the stops belt still catching so it kills the motor . if i take a small round peice of wood and put it between the sheaves pops right back to open... does this mean i have to rebuild the clutch or buy a new one ? i'm not all that farmilair with yamaha sleds got an old artic cat 340 jag that one is easy
well that's all i can think of at the moment
thanks in advance for the suggestions they are very helpful to me
maje1999
maje1999 is offline   Reply With Quote
Old 02-27-2005, 08:50 PM   #2 (permalink)
SergeantDHall
SergeantDHall's Avatar
maje1999,
First off, if the machine has been sitting for two years, it's time to do a compression test to find out what condition the top end is in, (120 lbs minumum each cylinder) and do a good carb cleaning along with checking the fuel pump! Pull the carbs and fuel pump and give them a good cleaning, making sure all ports and passages are free from any obstructions. Also, pull the seat, pop the rubber cap off the fuel tank, pull the fuel filter out and replace it. After the carbs are clean, re-install them and sync the carbs, and set the air screws for the pilot jets around 3/4 of a turn out from seated for a starting point.
In regard to the primary clutch, is it a stock Yamaha or a Comet? Whatever it is, it needs to be pulled, cleaned and gone through. All the rollers, weights, buttons, etc, need to be inspected, cleaned and replaced if neccessary. The reason I asked if it's a Yamaha or Comet is, if it's Yamaha, your going to need to take out a small second loan on your house to afford the parts! (Ha) Anyway, if the machine has been sitting for any length of time you'll need to go through the clutch and find out what spring is in the primary and replace it also, they (spring) should be replaced every two years if you ride quite alot.
I personally have two Exciters, they are relatively easy to maintain and they will provide hours of enjoyment if you take care of them, just like any other mechanical machine. Finally, get on Ebay or go to your local Yamaha Dealer and order a repair manual for it because you'll find yourself constantly refering to the manual for track adjustments and everything else required to maintain the machine!
Good Luck!
Dave
SergeantDHall is offline   Reply With Quote
