did you already buy it or your thinking about buying it?
i'd say save a little more and try to find a newer exciter with the 580 motor.
its a way better sled.
2 stroke motors are generally not to hard to rebuild. how good are you with working on stuff.
i could try to walk you thru it all.... do you have a digi cam in case you get stuck during the rebuild.... it helps a ton this way i can actually see what your working with
