Burning out sliders - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 15 (permalink) Old 02-11-2010, 07:39 AM Thread Starter
Burning out sliders
Well hopefully I will get an answer to this thread. With my possible purchase of a vmax 600 , i was thinking that this year we have no snow on the ice and I know this is bad for the sliders.
In a royal distributing catalogue they have a product that scratches the ice as you drive and sprays the sliders to keep them cool.
Any Idea how these work and if its worth it?
John in Ottawa
93_750storm is offline
post #2 of 15 (permalink) Old 02-11-2010, 08:16 AM
Quoted: 15 Post(s)
i use them on all my sleds, yes they work, yes they are worth it. i use holtz, rsi, and some from the billet store. dont know what type royal sells.
yamadad4 is offline
post #3 of 15 (permalink) Old 02-11-2010, 08:17 AM
Keep an eye on your sliders and if they get bad, replace them.
1986 Yamaha Phazer
1988 Yamaha Bravo
1990 Yamaha Phazer II
1992 Yamaha Phazer II
1996 Yamaha VMAX 500XT
rippintheyammi is offline
post #4 of 15 (permalink) Old 02-11-2010, 10:24 PM
Quoted: 91 Post(s)
I have 'em on all my sleds too. The scratchers throw up ice chips to help cool the engine and the chips melt and provide lubrication for longer hyfax life.
BC_Dan is offline
post #5 of 15 (permalink) Old 02-11-2010, 10:45 PM
FORGET WORK- I WANNA PLAY
TCOLLINS's Avatar
Can anyone post a pic of the scratchers installed on a sled. I have never seen them on a sled.
1998 Polaris Indy 500
1996 Yamaha Vmax 600
1991 Yamaha Phazer II48
1986 Yamaha SRV 540*Freebee*
TCOLLINS is offline
post #6 of 15 (permalink) Old 02-12-2010, 12:23 AM
Quoted: 91 Post(s)
Here's a link to a site that has three different types compared... google is your friend
Scratching the Snow
I have the Slidekicks on the sled in my avatar, if you have REALLY good vision, you can see 'em dangling just below the track
BC_Dan is offline
post #7 of 15 (permalink) Old 02-12-2010, 11:44 PM
TCOLLINS's Avatar
Do they mount in an existing hole or do you have to drill a hole?
TCOLLINS is offline
post #8 of 15 (permalink) Old 02-13-2010, 01:47 AM
Quoted: 91 Post(s)
Sometimes there's a convenient hole that will work.Some guys remove a bogey wheel and put the scratchers in that hole. I have used existing holes and have drilled holes as well. With the slidekicks, I drilled holes on the 3 sleds I have installed those on.
BC_Dan is offline
post #9 of 15 (permalink) Old 02-17-2010, 04:30 PM
They work great, you can also try Hiper-fax sliders, these are pricey but last longer, and the key thing to remember with ice scratchers is most of them need to be pulled up before using reverse!
08 S-D Renny 137 800 XP
7" powder hounds skis, 1.75 track, Fox zero P shocks, full vent kit w Summit drive belt & reduced gearing for power.
06 Yamaha Attak 136
stock, but alot of pics
08 Mirage Container w, 09 Safire 2 Main & smart reserve. Skydiving= what you do when there is no snow-haha
I don't care if its a 1975 or 2010 if it gets you out there & makes you smile its a good sled as long as it doesn't have an annoying can on it that pisses people off & closes riding area's!
Pzilly is offline
post #10 of 15 (permalink) Old 02-23-2010, 03:57 AM
Mooseman's Avatar
Even better, here a Youtube comparison between store bought scratchers and a cheap redneck solution that works better than all of them
YouTube - snowmobile scratcher tip
Sometimes, the simpler solutions are the best.
'07 Yamaha Venture Multi-Purpose
'92 Ski-Doo Safari L
'92 Ski-Doo Safari LE
Mooseman is offline
post #11 of 15 (permalink) Old 02-23-2010, 09:00 PM
I have a ? about replacing the slides....is it just a matter of just removing the rail end caps, and putting the slides on, or do I need to loosen the track first? Mine are wore down to the bare metal, but the rails and track clips look good, so in theory, the new slides will take up any slack if the track is a little loose, or ???
Current Sled: 1997 Yamaha Vmax 700 SX
Buzzkiller is offline
post #12 of 15 (permalink) Old 02-23-2010, 09:27 PM
shittykitty600
ANswer to your question about the slides. Check if they fit through the track window, if they do they make a slide hammer that screws in the back of your slide. They just pull out the back of your sled. Just loosen the nut up in the front of rail, and pull the bolt out. Otherwise you have to take the skid out, and yes the new slides should take the slack up in your track.
shittykitty600 is offline
post #13 of 15 (permalink) Old 02-23-2010, 10:55 PM
Quoted: 15 Post(s)
hyfax will come out the back through the track windows, not out the front by removing the caps. install them through the track windows. if yours are that shot, simply cut them off the rails with a sharp utility knife, taking care not to damage the rails. loosening the track helps a bunch. new hyfax will or should not change the tension of the track. worst isssue you will have is removing the #3 phillips screws that hold the hyfax on at the front of the rails. they are normally locktited in and the steel screws in the aluminum rails like to sieze in there. have an impact ready.
yamadad4 is offline
post #14 of 15 (permalink) Old 02-24-2010, 01:02 AM
Mooseman's Avatar
If your sled has reverse, it's even easier. Jack the rear, loosen your track as much as possible, remove the front retaining screws, start moving one of the slides out through a track window (an air zip gun works great or use a hammer and chisel/screwdriver), when you have a couple inches sticking out through the window, start the sled, put it in reverse and give it a LITTLE gas. The slide will peel right off. Repeat for the other slide.
This video shows the whole process, including installation:
YouTube - Nytro Hyfax J's Garage
Mooseman is offline
post #15 of 15 (permalink) Old 02-25-2010, 07:07 PM
Finally got the slides on. What an ordeal. She`s running and riding great now. Thanx for the help!
