Old 11-05-2009, 04:45 PM   #1 (permalink)
madmoose
Trouble Diagnosing Phazer Drive Train Noise
I have a 1994 Phazer II with pull start that has a rhythmic clunking sound when under load going up a grade. (It might be present going downhill, but if it is it's too quiet to be audible.) It is definitely drive train related, as it only happens when moving, and speeds up or slows down with sled speed, not motor RPMs. I have checked and adjusted both sheaves, the secondary sheave alignment and free play, the drive chain tension and the track tension. I have also checked motor mounts and all of the track guides and wheels for alignment, tightness and play. The biggest problem in diagnosis is when I lay it on it's side and run the track, it doesn't make the noise because it is not pulling a grade with a load.
This is making me crazy. Does anyone have any ideas?
madmoose is offline   Reply With Quote
Old 11-05-2009, 04:51 PM   #2 (permalink)
Replace the belt, it most likely has a chunk out of it.
Old 11-05-2009, 07:02 PM   #3 (permalink)
madmoose
V-Belt
Are you referring to the V-Belt? I had already inspected it briefly and it appeared fine, but I will give it a more thorough inspection and see if there are any problems. Thanks!
