Old 11-02-2009, 07:38 PM   #1 (permalink)
snow man ran
Question 700 sx
HEY im looking for a little help. I have a 97 700 sx. I ordered and new bender can and a bender primary clutch. I was wondering if i needed a puller to remove the clutch? I have a big 3 jaw automotive puller, but i dont wana break anything. Just looking fo some thoughts or ideas?
thanks snow man!
snow man ran is offline   Reply With Quote
Old 11-02-2009, 11:47 PM   #2 (permalink)
Viperstein
Go to your local Yamaha dealer and pickup a puller.They're like $25 or so.A big three jaw would be big trouble.
Viperstein is offline   Reply With Quote
Old 11-04-2009, 07:10 PM   #3 (permalink)
snow man ran
Thanks I ordered a puller. I now recieved the clutch kit. it only came with a purple spring and a alluminum plate. Does anyone know of a websit with instructions on installing this kit?
Old 11-05-2009, 11:56 AM   #4 (permalink)
Try Bender's website.
Old 11-12-2009, 09:02 PM   #5 (permalink)
snow man ran
ok thanks I have one more question. Is their a torque spec for the clutch?
Old 11-13-2009, 02:27 AM   #6 (permalink)
65 ft/lbs
Old 11-15-2009, 01:10 PM   #7 (permalink)
snow man ran
Thanks you have been a big help!!!!
Old 11-17-2009, 10:17 PM   #8 (permalink)
snow man ran
Hey I have another one to throw at you...Also on the 700sx i put the bender pipe and the clutch kit and boysen reeds. My Question is will I have to adjust the carbs in any way? The reed instructions said to turn the miture screw in 1/4 to 1/2 turns. I am basicaly wondering if the pipe and clutch will add to the adjustments?
Thanks snow man ran.
Old 11-19-2009, 10:59 PM   #9 (permalink)
yamadad4
torque spec is actually 85ft lbs, initial. then loosen bolt and retorque to 43ft lbs. as for the spring and spacer, remove the old spring and put the spacer under the new spring. bender springs are based on the short cover primary, and yours should be that cover, you may not need the spacer- let bender confirm or deny. as for your carbs, be darn sure you watch the plug color or check the piston wash, as pipes and reed changes will affect fuel mixtures.
