Old 10-28-2009, 09:57 PM   #1 (permalink)
Dylan9302
1988 Yamaha Phazer not pumping gas to carbs
Ok i got this sled and i had to clean the carbs. i cleaned them and tuned them. came back out the next day to see gas pouring out the pipe. I took the carbs out because i wanted to check the floats. they were at 9.6 mm when the manual says 11 to 13 mm. Set them at 11.5 and set them up with a gravity feed on my workbench and no leaking. Put them back in. changed the hose going from the top of the tank and put a new filter in and a shut off valve. turned the key over and over and no fuel getting pumped through. Can i be the pump went bad on me. The sled was running mint except the floats were bad. I had set it up with gravity gas and it leaked at 9.6mm float levels. I checked the hose on the pump, tank, and filter. i never put clamps on the shut of because the hoses seemed tight anyways. Im going to go back out tomoro and check for anymore leaks somehow. How do i check the fuel pump to see if it went bad on me.
Thanks Dylan
Dylan9302 is offline   Reply With Quote
Old 10-29-2009, 12:15 PM   #2 (permalink)
See if there is any fuel in the pulse line from the crank case to the pump.
If there is, the pump may have a bad diaphragm.
Old 10-29-2009, 12:38 PM   #3 (permalink)
p057
the lines hooked up correctly to the pump or the shut off valve is turned on
p057 is offline   Reply With Quote
Old 10-29-2009, 03:12 PM   #4 (permalink)
Dylan9302
ok thanks. il check to see if theres gas in the hose and yes i hooked the hoses up and tried the shut off both ways.
Old 10-29-2009, 06:58 PM   #5 (permalink)
TwinsofMLB
Themach1king
TwinsofMLB's Avatar
No pull cord, eh?
Yes I patented that
Old 10-29-2009, 07:35 PM   #6 (permalink)
Dylan9302
no ive been looking for one for it though.
