1988 Phazer oil pump drive gear
I have oil under the primary clutch on my 1988 Yamaha Phazer. I removed the clutch and noticed a seal where the oil pump drive gear is on the crank. Should there be oil in this area between the crank seal and the outer seal and what kind of oil?
