Old 10-22-2009, 09:05 PM   #1 (permalink)
asquare
asquare's Avatar
RX 1 won't start
Hey I have a 2003 rx1 just in thr progress to buy it ,it started geat when we picked it up but now it just keeps turning over any ideas
asquare is offline   Reply With Quote
Old 10-23-2009, 02:32 AM   #2 (permalink)
Kill switch in the run position?
Old 10-23-2009, 07:16 AM   #3 (permalink)
Foul the plugs?
Old 11-14-2009, 07:10 PM   #4 (permalink)
Assocracer
Pull one plug, leave it laying on the top of the head, then turn the sled over. If it sparks, then all of your ignition switches/coils/what not are working properly. Next, take off the air cleaner and spray some starting fluid into the velocity stacks on the carbs while your turning it over. If it catches, then dies, try it again. If you keep doing this with the same results for awhile, then you probably have a fuel delivery issue. On the left side top of the engine, you'll see the fuel pump assembly. It should have two fuel lines going in and two going out. Make sure you're getting fuel at those. How long did it sit after you bought it before you tried to start it?
Assocracer is offline   Reply With Quote
