It would be pretty costly to do at a dealer I beleive all the parts off of a simular year vmax would work on the srx the most economical way to do it would be to search for the used chaincase (with reverse gear) and associated reverse componets and swap these parts onto your sled. the gearing is different on the vmax a little slower top end so if you wanted to keep your taller gearing you would need to use your gears and then order the proper length chain to accomidate the taller gearing and the reverse gear. Its not a terribly difficult task to undertake and can be done at a reasonable cost if you can locate the used parts.
10 Ski Doo MXZ X 600Etec
03 Ski Doo rev x 800- Stolen
02 Yamaha vmax 700
02 Polaris edge 600
