Old 08-09-2009, 03:23 AM   #1 (permalink)
TheSnowPro
TheSnowPro's Avatar
89' Phazer Tach
i just recently picked up a 1989 yamaha phazer in very good shape. only thing that's wrong with it is the rpm gauge doesn't work. does anybody know how i can fix this? thanks in advance for the help.
TheSnowPro is offline   Reply With Quote
Old 10-02-2009, 03:59 PM   #2 (permalink)
agfirecat
whoratio
it is cable driven just like the speedo and works off the oil pump gear unscrew it from the tach start sled and rev it to see it it spins the cable.if not make sure its in the pump all the way if that dont help you may have to remove it from the pump to investigate a little further.
agfirecat is offline   Reply With Quote
Old 10-02-2009, 06:03 PM   #3 (permalink)
TCOLLINS
FORGET WORK- I WANNA PLAY
TCOLLINS's Avatar
Mine had a broken key. The reason was a seized up line. I bought new key and kept spraying WD-40 down the line to free it up. Worked great.
1998 Polaris Indy 500
1996 Yamaha Vmax 600
1991 Yamaha Phazer II480
1986 Yamaha SRV 540*Freebee*
Old 10-03-2009, 01:24 AM   #4 (permalink)
TheSnowPro
TheSnowPro's Avatar
thanks for the replys. ill check it out tomorrow afternoon and post with what i find. haven't really done much with it over the last month. been kinda busy.
Old 10-09-2009, 07:51 AM   #5 (permalink)
TheSnowPro
TheSnowPro's Avatar
well finally got some time to chack it out yesterday. turns out the end of the cable was broken off inside the oil pump. just need to get myself a new cable and im all set.
