Old 06-28-2009, 11:40 AM   #1 (permalink)
michiganman18
White Smoke In a 1991 Phazer II
I have a 1991 Yamaha Phazer 2, only dished out a couple of hundred bucks and looking back maybe i wouldnt have bought b/c the guy i bought it from was rude and hid a lot of stuff from me about the sled. But what done is done and i now need to know why it is smoking, it is a white smoke and isnt too noticable untill you rev up, then it just fogs ythe entire area, untill you let off the throttle, and it feels like it is almost cutting out on power but that may not be. Now i have not worked on any snowmobiles, just ATV's and outboards, as far as recreational use. Any ideas as to fix this problem, or check for issues, black usually mean rings, block, or cylinder damage; blue, oil of course, too rich, but white is puzzling, I've heard coolant but im not sure if this sled uses coolant or not, i do believe it is fan cooled. Any help would be great. What about antifreeze? Would there be any in a snowmobile thats causing it to smoke?
It isn't backfiring, starts in one pull, runs well, i thought i was noticing cut outs in power though when first started.
michiganman18 is offline   Reply With Quote
Old 06-28-2009, 11:48 AM   #2 (permalink)
polaris rider
PR (polaris rider)
polaris rider's Avatar
Welcome to the forum,
White could mean your running to rich.... are you letting it warm up for a long time? after about 15 mins take it for a nice rip around the house and then see if its still smoking alot at idle, if so probably oil leak, but it seems all old sleds smoke alot until warmed up real well(1/2 hour)
but for the cutting out issue, id go through and clean/rebuild carb..
1999 AC zl 500, 3k miles2003 polaris classic 340 1200 miles-2003 polaris indy xc 500 1500 miles-2000 polaris xc 700 6500 miles-2003 arctic cat zl 600 1500 miles
"Dont let fear and common sense stand in your way!"
polaris rider is offline   Reply With Quote
Old 06-28-2009, 02:47 PM   #3 (permalink)
BC_Dan
The Phaser is a fan-cooled sled, so no antifreeze. Like Polaris Rider said, it's probably running rich. Sleds are jetted for cold temps, they always run rich in the summer. If it starts easily and seems to run ok, it's probably fine. I would wait until it gets a lot colder to do any serious adjusting...
Here's a link to Yamaha's online Microfiche, you may find it useful
My Yamaha Prompt - Parts Catalog
Old 06-28-2009, 06:34 PM   #4 (permalink)
TCOLLINS
FORGET WORK- I WANNA PLAY
TCOLLINS's Avatar
My phazer also smokes alot. Wait for winter and once you ride it for awhile it will probably be less smokey????
1998 Polaris Indy 500
1996 Yamaha Vmax 600
1991 Yamaha Phazer II480
1986 Yamaha SRV 540*Freebee*
