87 Enticer, no spark
I have an 87 enticer 340, which has no spark. If I test the wire going to the coil with the ignition on I get about a .5 reading on the voltmeter, I am guessing this is the signal coming from the stater... Is this enough? do I need a coil or a stater or am I overlooking something... dont know much about small engines... but I know enough about large engines..
the sled has been parked outside uncovered for about 5 years, turns over great, cleaned up the carb, and everything around... trying to get her going for as cheap as possible... ofcourse.
any help would be appreciated
