Old 02-24-2008, 11:01 PM   #1 (permalink)
TCOLLINS
FORGET WORK- I WANNA PLAY
TCOLLINS's Avatar
Question chaincase drain plug????
Is there a chaincase drain plug on 1991 PhazerII and 1997 VMAX? If so where?
1998 Polaris Indy 500
1996 Yamaha Vmax
1991 Yamaha Phazer II
Old 02-24-2008, 11:10 PM   #2 (permalink)
IRONDOG
The Phazer, no. The V-max, yes, on the back of the case in the tunnel.
Jerry
www.snowmobileswapmeet.com
Old 02-25-2008, 04:03 PM   #3 (permalink)
TCOLLINS
TCOLLINS's Avatar
Jerry
Thanks, Jerry. I will take a look.
1996 Yamaha Vmax
Old 02-26-2008, 12:19 AM   #4 (permalink)
TCOLLINS
TCOLLINS's Avatar
when I looked at the vmax there is a stamped sign that says drain. There is no arrow but there is a screw next to the word drain. It looks like all the other screws on the case. Would that be the one to drain the oil?
1996 Yamaha Vmax
Old 02-26-2008, 12:38 AM   #5 (permalink)
IRONDOG
I thought you had a 1997 V-Max- did you recently change your signature from 1997 to 1996 V-Max? My answer about the 1997 V-max was accurate. Yes, the '96 also has a drain bolt, lower right side of cover. It has a sealing washer on it also.
Jerry
Old 02-26-2008, 12:39 AM   #6 (permalink)
derrickleejr17
derrickleejr17's Avatar
Usually the drain plug is located on the bottom of the chain case excessible from the bottom of the belly pan. And probably a allen key needed to remove it.
derrickleejr17 is offline   Reply With Quote
Old 02-26-2008, 11:05 PM   #7 (permalink)
TCOLLINS
TCOLLINS's Avatar
Jerry
Yes jerry I fuc&*d up. It is a 1996. I was looking for the drain plug and noticed the 1997 has an oil dipstick and the 1996 doesn't. Mine doesn't so it must be a 1996. Also you mentioned that the Phazer 1991 does not have drain plug. Mine has the same screw with the same sealing washer on the bottom right side of the chaincase. I can't guarantee the Phazer has the original chaincase either. I bought these sleds this year and I am learning alot about them.
1996 Yamaha Vmax
