Is the casing lax, or is the cable that goes to the choke lever lax? What motor do you have? Without more info, i would suspect that it is in the open position. Is it hard to start when its cold, or does it run like its flooding out once its warm? You could take the air box off to see if its open or closed. You may want to go through the carb to clean and reset the jets. That might get your fuel consumption back to original specs.
1989 Yamaha Exciter My Sled
1985 Yamaha XLV Wifes Sled
1977 Arctic Cat Kitty Kat Sons Sled
