Originally Posted by RJ Gleason
If you have to keep "working the choke" to keep it running at idle/low speed, clean the carbs, the idle circuit is partially or completely plugged.
Thats the kicker.. These carbs spotless.. Yammy guy agreed.. (I spent a lot of time cleaning them)
Update from yammy guy:
1) secondary not quite right but probably not the culprit.
2) Very deep snow maybe getting on exhaust pipe (causing steam) Steam is more dense and could be leaning it out
3) This one got me thinking instead of using clamps the feller I bought it from used wire and twisted it tight to seal the fuel line..(on the pump where my hands don't fit, possibly letting air in when it warmed up) They found air in that line.. A good maybe on this one.
4) while the pump tested out ok with mouth pressure it's still is 20 years old and I have no idea how long it sat for..
So it has all new fuel line, and I'm having them throw a pump in it (so I don't have to)
I saw the wire on the line and thought nothing of it.. But in hindsite the wire does cut into the line. A cut line is bad.. Even if it just sucks air just a tad.. (or so I'm told)
