rx1 misfire - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 11 (permalink) Old 12-30-2007, 09:55 PM Thread Starter
Question rx1 misfire
I Have A 2003 Rx1......new To Me, But Has 4311 Miles On It. Just Changed Plugs; Cleaned Air Box And Filter; Changed Oil And Filter Greased Suspension Etc. Anyway Put 112 Miles On It Today, But About 1/5 Of The Time It Would Experence Misfiring;complete Stalling Out;back Firing Out The Exhaust......then For No Apparent Reason Run Like A Raped Ape.......what Goes..........any Ideas. Thanks In Advance For Any Info......imo I Am Thinking Ignition....anybody Else.
jergy2.0 is offline
post #2 of 11 (permalink) Old 12-31-2007, 02:18 AM
Gunk in the carbs or water in the fuel.
Seafoam will possibly fix it.
post #3 of 11 (permalink) Old 12-31-2007, 09:41 PM Thread Starter
THANKS FOR THE REPLY.....THERE IS A HALF A TANK IN THE SLED NOW, HOW MUCH WOULD RECOMEND TO PUT IN THE TANK AND OR FILL THE TANK.....HAVE BEEN READING SOME OTHER THREADS ON THE ISSUE AND THINK I'LL ALSO TRY TO CLEAN THE PILOT JETS AS WELL, YOUR INPUT?????? THANKS FOR THE REPLY
jergy2.0 is offline
post #4 of 11 (permalink) Old 01-01-2008, 08:44 AM
This may sound silly, but are the plug wires are on tight? and are on the right order? I used to always number mine and spray WD-40 in the inside of the "Boot" in ensure no problems.
I hope you find the issue.
yooper1 is offline
post #5 of 11 (permalink) Old 01-01-2008, 01:47 PM Thread Starter
Yeh, I Know They Are On Correctly, Because When It's Not Misfiring It Runs Great........and Yes I've Pushed Down Hard On The Caps/wires........does Anyone Think It Could Be Cdi Module Related ??????
jergy2.0 is offline
post #6 of 11 (permalink) Old 01-02-2008, 08:29 PM Thread Starter
Just An Update As To Whats Going On.......today I Checked The New Plugs That I Had Put In Recently, They Look Great, Tan In Color . I Cleaned The Coils And Sprayed Wiyh Moistier Inhibitor ......got To Looking Around And Decieded To Look Into The Gas Tank, And Noticed What Looked Like Alot Of Settlement And Metalic Like Substance In There....thought This Ain't Right.......so I Proceed To Remove The Tank To Clean It. I Found Two In The Tank Fuel Filters And One Of Them Appeared To Be Starting To Come Apart....needless To Say I Replaced Them. Tommorro I'll Put It All Back Together, And Try It Before The 50 Degree Weather Gets Herre Thats Coming This Weekend. I Don't Want To Do The Seafoam Right Know As I'll Be Putting In Fresh New Gas.....and Hopefully I'll Not Need To Take The Carbs Apart Yet. I'll Keep You Updated As To My Findings As They Develop......
2003 RX1
2006 RAPTOR 50
2005 RAPTOR 660
jergy2.0 is offline
post #7 of 11 (permalink) Old 01-02-2008, 11:17 PM
WHAAAAAAAAAAAAAAP!
rightarm's Avatar
check the wiring harness in the nose of the sled around where the tool box is or used to be.03 had a problem in this area rubbing through the insulasion
GENESIS 4 STROKE EXTREME
KEEP THE RUBBER SIDE DOWN
TRUE NORTH STRONG & FREE
TAKE OFF EH! YA HOSER!
rightarm is offline
post #8 of 11 (permalink) Old 01-03-2008, 08:44 AM
JD
TUGHILLYAMMI's Avatar
Crazy question but what were the conditions? My buddy with the same sled had this problem with the T.O.R.S. sensor deal. It was rainy and icy and his throttle sensor iced up on him with not enough play. Check it out it might be benneficial
TUGHILLYAMMI is offline
post #9 of 11 (permalink) Old 01-03-2008, 06:57 PM Thread Starter
The T.o.r.s. Are Disconnected, So I Think That Can Be Elimiated.....the Conditions Were 30 Degrees Not Snowing, So No Icing Problems..........i Was To Busy To Get Fresh Gas And Try It After Cleaning Today, Maybe Tommorro....
2003 RX1
2006 RAPTOR 50
2005 RAPTOR 660
jergy2.0 is offline
post #10 of 11 (permalink) Old 01-04-2008, 07:31 PM Thread Starter
Well I Was Able To Get Fresh Gas And Try It Out Today, But Only For A Few Miles. It Seems To Be Normal(runs Like A Cheetta) Hopfully That Takes Care Of It......
2003 RX1
2006 RAPTOR 50
2005 RAPTOR 660
jergy2.0 is offline
post #11 of 11 (permalink) Old 02-16-2009, 03:42 PM
check for water in the vacuum lines
cjrama is offline
