Old 12-23-2007, 10:59 PM   #1 (permalink)
Archer
Apex??
I just bought a 06 Apex and I love the power and the ride but in some of the turns it wanted to flop over and play dead I have not had this problem with older sleds (Jag and El Tegre)
So what do I have to change in my riding stile to fix this?
Archer is offline   Reply With Quote
Old 12-24-2007, 03:19 AM   #2 (permalink)
big bore king
Mr Polaris
big bore king's Avatar
They require alot more muscle to corner than the old sleds due to the extra weight. You need to realy lean forward and out when cornering. Also play with the adjustments on the front suspension until you find the best setting for your riding style.
Anything stock pretty much sucks!
2001 Polaris 600xcsp(sks) 1.5 paddle
2002 Polaris 500xcsp 1.25 paddle
1996 Polaris Ultra SP
2000 Polaris XCR 120
2000 Polaris trail blazer 250.
2001 Yamaha Big Bear 400
2000 Honda TRX 90
big bore king is offline   Reply With Quote
Old 12-24-2007, 04:56 PM   #3 (permalink)
Snakeman
Snakeman's Avatar
It just needs to be set up.Dealers for the most part don't touch the set-up on them.They will tell you they did,but mostly they just bolt on the ski's and handle bars and kick them out.I've ridden my nephews and I've also followed it a lot and it will sit as flat in the tight twisties as any sled as hard as you want to push it.
Snakeman is offline   Reply With Quote
Old 12-25-2007, 11:40 AM   #4 (permalink)
Archer
Thanks
Any tips on what adjustments to start with
Old 12-25-2007, 09:03 PM   #5 (permalink)
Octane
Amateur Lumberjack
Octane's Avatar
Id start by take away some of the front suspension shock spring preload. Thats going to allow the body to roll more in the corners and reduce the tippyness.
Also, try leaning more in the corners. You may need to try taking your feet out of the stirrups and leaning farther off on the side of the sled.
I demo rode an Apex a couple years ago and I found it to be kind tippy too, so you arent alone.
'01 Polaris Indy 600 XC SP EDGE X
Powermadd articulating bar riser with 2" riser block (total rise of 4 1/2")
Pro-X seat
red Cobra low sno-x windshield
Pure Polaris handguards with Pure Polaris mounts
almond/blue drive clutch spring with 10-60 weights
121" x 15" x .91" track with 96 studs.
7,100 miles
Octane is offline   Reply With Quote
Old 01-02-2008, 11:42 PM   #6 (permalink)
rightarm
WHAAAAAAAAAAAAAAP!
rightarm's Avatar
Loosen front springs till loose than tighten about 4 turns,go up on the limiter strap and try to throttle through the turn not hard just steady.If lateral momentum becomes greater than forward momentum it will cause the ski lift.
GENESIS 4 STROKE EXTREME
KEEP THE RUBBER SIDE DOWN
TRUE NORTH STRONG & FREE
TAKE OFF EH! YA HOSER!
rightarm is offline   Reply With Quote
