Old 12-16-2007, 09:50 AM   #1 (permalink)
Knight
Do I have a head gasket problem?
I have a "03" Venture 700 w/ 650 miles. It was running like crap, so I cleaned the carbs. While reinstalling the carbs, I noticed coolant in the clear compression hose that runs to the fuel pump. Coolant level was down. Now it idles high and floats. I can't get the idle down unless, I apply some choke.
What causes head gasket failure on a low milage machine? I did have a backfire last year that blew the expansion camber off the springs.
Knight is offline   Reply With Quote
Old 12-17-2007, 05:12 AM   #2 (permalink)
Could be head gasket, base gasket or crack in the wall. Only one way to find out.
Old 12-17-2007, 06:58 AM   #3 (permalink)
Failure can be caused by a number of things. The backfire is a good way, it could have torn the O-ring on the top of the jug.
Old 12-17-2007, 09:40 PM   #4 (permalink)
Knight
UPDATE;
Not a head gasket problem. The green coolant I saw in the fuel line was oil injection line to the fuel pump. The coolant level down was coolant lost carb cleaning.
I took the machine to a local shop and he will get the triple carbs running correctly.
