Usually the jetting chart is for stock exhaust. You may want to go up one or two jet sizes for aftermarket exhaust. Remember that main jets only effect throttle position of about 3/4 to full throttle.
If you don't run the sled hard your jetting was fine, but when you ran it hard the lean condition started. Fatten up the mains, better to run a bit rich than lean. You can also install a Variflow and be able to adjust the jetting on a remote dial. They work great.
Lster
