Old 12-11-2007, 03:29 PM   #1 (permalink)
Jimbo26
85 XLV Help
I recently purchased and 85 xlv 540. Starts great runs great for about 2 mins.at which time all it wants to do is idle. Let it sit for 5 or so mins(off) runs great again for a couple mins. I have cleaned carbs ,changed gas and plugs still the same.
Any help would be great
Thanks Jimbo
Jimbo26 is offline   Reply With Quote
Old 12-11-2007, 07:36 PM   #2 (permalink)
kccats
A few things to check would be, the pick up in the tank, the tank itself, fuel filter and the fuel pump?
Old 12-11-2007, 07:45 PM   #3 (permalink)
Jimbo26
Thank you very much I will be on it 1st thing in the morning.
Old 12-11-2007, 08:06 PM   #4 (permalink)
Jim Jessup
Hiberna Somnium
Jim Jessup's Avatar
After that you should check the crank seals. Sometimes when they go bad they do the same thing you're describing.
The fleet...
1989 Ski-Doo Formula Mach 1
1996 Yamaha Vmax-4
1997 Ski-Doo Mach 1
1998 Yamaha Venture
1999 Ski-Doo Formula S
Jim Jessup is offline   Reply With Quote
Old 12-11-2007, 08:38 PM   #5 (permalink)
zilla600
zilla600's Avatar
What about the T.O.R.S on the throttle?
1989 Yamaha Exciter My Sled
1985 Yamaha XLV Wifes Sled
1977 Arctic Cat Kitty Kat Sons Sled
zilla600 is offline   Reply With Quote
Old 12-13-2007, 12:12 PM   #6 (permalink)
Jimbo26
The compression is in the low 90 "s . Would this contribute to the problem?
Old 12-13-2007, 12:58 PM   #7 (permalink)
zilla600
zilla600's Avatar
It very well could. Compression should be at least 120psi. How many miles are on it?
Old 12-13-2007, 01:41 PM   #8 (permalink)
Jimbo26
9763
thanks
Old 12-13-2007, 03:24 PM   #9 (permalink)
zilla600
zilla600's Avatar
Well its good to know i can expect to get that many miles out of my 85xlv. I have less than 2000 and the PSI is around 130 in each cylinder. It sounds like (to me) that your cylinders are worn out, and once it starts to warm up, they become out of round and you loose compression. I would get ahold of smallengineguy, he may shed more light onto it.
