Carb question
I volunteered to help my neighbor resurrect a 1980ish EX440D. It has been left neglected, uncovered in his back yard for the last 3 years. Being a Yamaha I had confidence that it would still run if it wasn't seized.
To make a long story short, it runs great if you pour gas down the throat of the carb. One pull and it runs until the prime is gone. (I used the 50:1 mix I have for my 3.3hp Merc dinghy motor)
The fuel pump is pumping so I think a carb rebuild should fix the problem. The choke is frozen although the cable is not. Does anyone know if the choke cable is attached to a piston that should pull out? I can't see any other way to remove the choke cable but am afraid to yank too hard without knowing for sure.
Thanks
rjr
