Old 12-08-2007, 03:57 PM   #1 (permalink)
wmw
Can't Get 600 Or 700 Started!!!
I have tryed every thing!
New plugs/gas,I have been at it all day still nothing!
these 2 yamahas(99&2000)were allways hard to start but I did get em started!
maybe a good tune up is in order, what do ya think?
wmw is offline   Reply With Quote
Old 12-08-2007, 04:08 PM   #2 (permalink)
Polaredge
Polaredge's Avatar
try taking the carbs apart and give them a thorough cleaning and make sure the kill switch if off
2002 Polaris 700 Edge X 136" Track,1 1/4" lugs,extra cooler,3" riser
2004 Arctic Cat F7 128" x 1.375" track, 6" riser, Fly low rise bars, MBRP can, Fox Zero Pro shocks, Fly low windshield
Always remember There is no such thing as too much RED MEAT or HORSE POWER
Polaredge is offline   Reply With Quote
Old 12-08-2007, 04:09 PM   #3 (permalink)
Were they just parked last spring without doing anything to prevent the fuel from going bad? If so, you're probably going to have to remove and clean the carbs.
Old 12-15-2007, 03:16 AM   #4 (permalink)
97yamahamm700
step 1. Take spark plugs out.
step 2. Pour SMALL amount of gas into plug holes.
step 3. insert spark plugs
step 4. pull and it should start after a good pull or few.
repeat if needed. it just gets it running for a few seconds to start getting gas running through the carbs again..instead of pulling it over a ton..unlike the older skidoos which have primers.
just a trick of the non fuel injected 2 strokes.
it worked for me about 2 weeks ago.
hope this helped.
also...a thorough cleaning of the carbs can help
97yamahamm700 is offline   Reply With Quote
Old 12-15-2007, 06:27 AM   #5 (permalink)
lrnnorth
Above The Arctic Circle
lrnnorth's Avatar
Did you check for spark and do a compression test?
01 Polaris RMK 136"
- 01 600 VES Engine - Uni Air Filters
- Sno Stuff Rumble Pack - Powermadd Boost Bottle
- Custom Painted Hood - Powermadd Bar Riser
- EPI Pro Series Clutch Kit - Xtra-10 rear suspension
01 Yamaha VK III 540 (The TANK)
Out Of Commission Till Next Year
lrnnorth is offline   Reply With Quote
Old 12-15-2007, 06:58 AM   #6 (permalink)
FROSTBITTEN
This might sound alittle strange, but I always force the fuel throught the carbs by blowing in the tank. Just clean the area where the cap fits and just pucker up and blow in the tank to presurize it, forcing the fuel into and throught the carbs. do this once or twice,also MAKE SURE YOU HAVE SPARK. If you do it should start. Hope this helps.
FROSTBITTEN is offline   Reply With Quote
Old 12-15-2007, 07:11 AM   #7 (permalink)
lrnnorth
lrnnorth's Avatar
I blow in the tank all the time. Just make sure you blow and not suck. lol
01 Polaris RMK 136"
Old 12-22-2007, 07:42 PM   #8 (permalink)
raiderx65
and use GAS not starting fluid.
raiderx65 is offline   Reply With Quote
