I gotta tell ya that sled has the most complicated fuel system on it. A couple of things I did to mine, besides regearing it, I cut that piece of plastic that doesn't move when you open the hood, off! I took a pair of small "L" brackets and pop rivited them on so that the bolts that hold the side panels on also hold it on too. Now you can lift the air box right out simple! If you have one fuel pump with two outlets the lines just go to each carb. 2 pumps there is a ballancing "T" between them. One pump one outlet there is a "T" to branch to each carb. The line from the tank goes up to the shut off valve on the upper right side, then back to the pump threw a filter. Good luck and clean those carbs!
