Old 12-03-2007, 04:36 PM   #1 (permalink)
JoeFromBoston
Carbides for 1991 Yamaha Phazer II
Hi All. I am new to snowmobiling. I picked up a used Phazer with 1600 miles on it. Thing looks/runs like brand new. I took it out for a ride this morning (first snow) and it ran great. The only problem was slow speed turns. The skis both turned fine but the sled didn't want to go easily. I am thinking I need new carbides. What should I get? Single/dual channel? 4", 6", 8"? Can anyone reccomend a brand? Thanks much!
JoeFromBoston is offline   Reply With Quote
Old 12-03-2007, 07:48 PM   #2 (permalink)
jKsled
Sconnie
jKsled's Avatar
If you don't have much snow, then it will be hard to turn. more than a couple inches, and it's still not turning, then you might need carbides. you can look at them, make sure they are thick enough. a normal wear bar will be a thick weld when it's new, a carbide will look like a little blade. test it in good snow before you get new ones, and make sure they're actually worn. just lift the front of the ski up by the handle and look at them.
~If you dont think it's bad @zz, then whats the point?~
1990 Skidoo Formula MX 470
1986 Ford Ranger 2.9L 4x4
3"body lift
3" Skyjacker suspension lift
dual custom exhaust
Old 12-03-2007, 07:54 PM   #3 (permalink)
badbrad
saskatchewan sledder
badbrad's Avatar
my 93 venture gt, i couldnt find anything to fit it anywhere so i made my own by bending steel rod and welding on bolts with there heads cut off.
Whatever is written above is just my $.02
My family puts the "fun" back in dysFUNctional.
whoever said nothing is impossible, never tried slamming a revolving door
badbrad is offline   Reply With Quote
Old 12-03-2007, 08:34 PM   #4 (permalink)
Gunner
Gunner's Avatar
X2
Mine were worn nice and flat, so I just got some 3/8 round bar, cut the original on either end of the furthest bolts and bent the bar to fit and welded it to my old one... $10 worth of steel and half an hour and I was done. Did that about 1200 miles ago.. Still there..
That was on a 93 Phazer II ST
Gunner is offline   Reply With Quote
Old 12-03-2007, 08:38 PM   #5 (permalink)
Check the misc parts section of this forum, then click on parts links for aftermarket distributors. If you have NO studs, go wit hthe 4". Up to 96 studs, 6".
Old 12-03-2007, 10:23 PM   #6 (permalink)
zilla600
zilla600's Avatar
I just saw some on ebay, might be worth looking into.
zilla600 is offline   Reply With Quote
Old 12-04-2007, 07:47 AM   #7 (permalink)
JoeFromBoston
You guys are awesome. Thank you all for the ideas. I think i'll wait until we get a decent snowfall and try it out again. Only 2-3" on the ground right now.
