Thank you!
When a coil begins to get bad, does it affect both cylinder. I mean, is the coil separated inside so each side is independant? I suspect the coil since the carb seems to be fine.
The sled doesn't pull hard at all and It fools plugs. When I stored it the last spring, it was running well.
Intake is clean, exhaust seems to be fine. I cleaned the carb...
Is there a way to test to coil? ohm values or something?
THanks
