Old 02-13-2007, 08:00 PM   #1 (permalink)
WEATHERBY460
V-MAX WILL NOT FIRE after new head gasket
of course...92 v-max 4
put it back together and it wont start. don't seem to have any spark
heres what I did>>>
put new head gaskets in
removed carbs and cleaned
unhooked throttle cable and hooked back up
unhooked choke cable and hooked back up
removed air boxes to carbs and reinstalled
unhooked 2 coils, hooked back up
unhooked temp sensor and cable going to carbs and hooked back up
thats it!
I ohmed the key switch and kill switch...ohmed ok
As far as the carb switch and throttle switch...should they be open(reading resistance) or closed (open resistance)
what else could I have done wrong?
Thanks.
Old 02-14-2007, 04:26 PM   #2 (permalink)
WEATHERBY460
I ohmed out the primary, secondary, charge, and pulser coils.
All read what the specs call out for.
Please advise what I should try next.
Old 02-14-2007, 06:58 PM   #3 (permalink)
MXZ670Rider
MXZ670Rider's Avatar
did ya check the ohmes comin out of the stator?
It's a downright joy for a country boy
when he hears them engines moan .
'02 Arctic Cat ZR800 bored to a 1010cc Psi pipes, vforce reeds, clutched, works suspension.
'96 Arctic Cat Wild cat 700 efi
'77 Arctic Cat Pantera (reconditioning it)
'01 Yamaha blaster 200 with custom exhaust
'06 Arctic Cat 650 Twin
Wheel horse garden tractor w/ 10hp kohler. does 35mph ,2 seats, stereo, wheelies.
racing lawnmower 18hp kohler bored +.025 over, racing cams,egged head. 60mph
MXZ670Rider is offline   Reply With Quote
Old 02-14-2007, 07:10 PM   #4 (permalink)
WEATHERBY460
i think thats my primary and secondary coils?
Old 02-14-2007, 09:57 PM   #5 (permalink)
SnowRida
Runnin Against The Wind!
SnowRida's Avatar
Looks like you bought someone else's problems. Check the coils. Good luck to ya.
SnowRida
Yamaha V-Max
02 MXZ 600
97 Polaris Indy Trail Touring
Old 02-15-2007, 07:30 AM   #6 (permalink)
Did it run before you took it apart?
Old 02-15-2007, 07:04 PM   #7 (permalink)
kccats
Did you loose the magnets in the carbs?
Old 02-16-2007, 04:19 AM   #8 (permalink)
WEATHERBY460
WHAT are the magnets, and what do they do.....thanks?
Old 02-16-2007, 08:36 AM   #9 (permalink)
kccats
Not sure on that motor , but the carb saftey switches use a magnet in the slides to operat the switch!
Old 02-24-2007, 08:06 AM   #10 (permalink)
WEATHERBY460
update....
took it to a shop on monday, called them yesterday,
they can not figure it out either what is wrong.
everything checks ok
ordered a cdi, hopefully that went bad somehow.
thanks.
