Old 02-07-2007, 02:54 PM   #1 (permalink)
Arctic_Cat661
More Vmax Problems
I have a 1997 vmax 600 XT...I recently snapped both the tensioner bars..I took out the suspension to replace them and by the time i put it back in the sled had been sitting for 2 weeks...now excited to ride i fired it up it started no problem 3 pulls but its not preforming right at first i thaught it was running on one cilinder because when i pulled the plugs only one was wet..but now when i run it they are both wet..the sound is completely off and it also lets out the odd backfire..i have no idea what the problem could be...Perhaps it froze up, c arbs need cleaned....also after letting it run a dark oil or greas of some sort it coving the manifold that was never there before....not too sure if there is a gasket or something between the heads and the manifold but if there is this could be a problem as well.....any inputs would be greatly appreciated thatx
Arctic_Cat661 is offline   Reply With Quote
Old 02-07-2007, 07:13 PM   #2 (permalink)
bansheex
Stupid question but did you try 2 new plugs? The oil is probably just seeping out of the manifold because it is flooded.Try 2 new plug,then check compression,finally if it has good compression,pull the carbs.
1998 Mxz 670
1998 Vmax 500 XT
1990 Prowler 440 L/C
bansheex is offline   Reply With Quote
Old 02-07-2007, 08:10 PM   #3 (permalink)
Arctic_Cat661
I know for sure that the compression is fine i just put to brand new wiscos in it....And i never tried plugs but no kidding that has to be whats wrong the sled was on a jack with the ass end lifted for two weeks alot of fuel moved forward in it duhhh...thank you i will have to try that and get back to you...
Old 02-07-2007, 09:40 PM   #4 (permalink)
kccats
Pull the plugs and pull it over a bunch then put the plugs in and run it with the track up at 1/2 throtle till she cleans out.
