Old 02-06-2007, 08:28 PM   #1 (permalink)
WEATHERBY460
Radiator Caps Yamaha?
I am having an overheating problem on my 92 v-max.
I would like to try a new cap. Will an automotive one work?
Or are they specialized?
Thanks for the help.
Old 02-07-2007, 09:54 PM   #2 (permalink)
kccats
Just check the lbs rating! Are you getting bubles? if so likely a blown head gasket!
Old 02-08-2007, 05:09 AM   #3 (permalink)
WEATHERBY460
Not sure were to look for bubbles...but here is what I have done.
Replaced the thermostat and cap.
Purged the heat exchanges in the back under the seat.
I notice the resivior tank level never changes. I thought as the coolant get hot, it raises or lowers the coolant in the resivior.????
Today I will try to purge air again. And also try to find the bolt at the water pump and see if any air is in there.
Please advise....thanks
Old 02-08-2007, 08:23 AM   #4 (permalink)
kccats
Raise the front of the sled as high as possible with the engine warm and running with out the cap. Get a tester and make sure it's a 50/50 mix!! With the coolant toped off at the cadiator cap watch for bubbles? Don't worry about the resivor.
Old 02-08-2007, 02:42 PM   #5 (permalink)
WEATHERBY460
thanks kkcats...will give it a try
