Old 02-02-2007, 04:56 PM   #1 (permalink)
NY Snowman
NY Snowman's Avatar
05 Rs Rage No Start
I find it hard to believe that this hasn't happened before to anyone, the sled suddenly just quit. You turn it over it just clicks. Nothing. New battery didnt help. Probably starter. Not good.
NY Snowman is offline   Reply With Quote
Old 02-02-2007, 07:10 PM   #2 (permalink)
mmrosshere
Wants to see snow
mmrosshere's Avatar
What happens when you pull it with the cord. Will it start? Does it feel stuck? Was it running and it died or did it just quit starting with the key?
84 srv 540 starting to mod
98 indy classic xlt 600
LET ME OUT OF THE HOUSE
Old 02-02-2007, 08:56 PM   #3 (permalink)
NY Snowman
NY Snowman's Avatar
No pull cord, Engine not stuck, can turn by hand stopped while at idle. At dealer now, PIECE OF SH**
Old 02-02-2007, 09:42 PM   #4 (permalink)
mmrosshere
Wants to see snow
mmrosshere's Avatar
Well I didn't think that they would make a sled that did not have a aux starting method. Foolish me. They have perfected them so well that a secondary system is not needed. I am a strong advocate for redundancey in something that can leave you in the middle of nowhere.
Old 02-02-2007, 11:31 PM   #5 (permalink)
Apex ER Man
It's a 4 stroke,you can't pull a 4 stroke over. Your car doesn't have a cord does it? Same thing kind of.
Apex ER Man is offline   Reply With Quote
Old 02-03-2007, 01:29 AM   #6 (permalink)
mmrosshere
Wants to see snow
mmrosshere's Avatar
You have point there. I am just not real enthused with the way things are going. first they take away the crank on a car then the kick on a bike. Now the pull on the sled. As far as the rope on a car there is a little diff. between 1000cc and 5000cc. I have however pull started (with a rope and tiedown strap) a datson(sp?) b210 several times, a toyota supra and ford ranger. all were autos so the could not be pop started. Just wrap the rope around the crank pulley or harmonic balancer an retard the timing. Yes you can pull over a car motor like that.
Old 02-03-2007, 05:39 AM   #7 (permalink)
SnowRida
Runnin Against The Wind!
SnowRida's Avatar
Lawn mower engines have pull cords.
SnowRida
Yamaha V-Max
02 MXZ 600
97 Polaris Indy Trail Touring
Old 02-03-2007, 06:25 AM   #8 (permalink)
NY Snowman
NY Snowman's Avatar
4 stroke atv's have pull cords. I agree they should have a aux starting method because everybody doesn't carry a set of jumper cables in the middle of the woods do they????
Old 02-03-2007, 07:23 AM   #9 (permalink)
Apex ER Man
I guess all your points are accurate,it's just since this is my first Yamaha everybody has said you can't do it to a 4 stroke,forgetting that atv's and lawnmowers do? I do carry a tiny set of cables on mine just in case I need a jump. Maybe they mean like on these 1000cc 4 strokes it's just way to hard to pull over in the cold environment that it's in,just like on cars as an alternate starter,too much motor to be pulling on. I know when I owned a 900cc Polaris Fusion [2 stroke] it was not fun to pull over when it got below 10 degrees. If you are in a warm shop things always start better.
Old 02-06-2007, 02:56 PM   #10 (permalink)
jus4plamichigan
Ride the Tipp of the Mitt
jus4plamichigan's Avatar
So what did you find out?
What Happens @ The Tipp of The Mitt,
Stays @ The Tipp of The Mitt
jus4plamichigan is offline   Reply With Quote
Old 02-06-2007, 04:22 PM   #11 (permalink)
NY Snowman
NY Snowman's Avatar
Starter. Can't believe it. 10-15 hours labor to remove it, got to pull engine...
Old 02-06-2007, 06:17 PM   #12 (permalink)
mmrosshere
Wants to see snow
mmrosshere's Avatar
Ouch sounds like big bucks in labor. Did you ask about a secondary emergency start?
