Old 01-18-2007, 05:46 PM   #1 (permalink)
stickyicky
93 exciter sx driveline prob's/viabration
Hey guys just wondering if anyone could help me out! I was loading my sled (93 exciter) on a trailer, it was under high rev's, belt smoked a bit and clutch was hot. So i took it off the trailer took it for a boot and now im getting a viabration coming from the driveline. the vibration does go away when i pin it. I changed the belt with a new one, used steel wool on the clutches to remove rubber... and still the same.. any suggestions on what it could be. it worked fine untill i loaded it on the trailer. thanks
stickyicky is offline   Reply With Quote
Old 01-19-2007, 01:17 PM   #2 (permalink)
Use a straight edge and check that the sheaves are not warped.
Old 01-19-2007, 03:37 PM   #3 (permalink)
stickyicky
will do ill let ya know if they are... the shop wants $300 to change all my bearings and sliders they think this may be causing the prob.. should i have them do it?
Old 01-19-2007, 03:51 PM   #4 (permalink)
kccats
If they are going to change all! your bearings and hyfax for 300 it might be worth it. the track bearings are hard enough to change but the jack shaft can be worse. And all the idlers too?
Old 01-19-2007, 04:13 PM   #5 (permalink)
stickyicky
no idlers, I thought this was a bit much, I would have dont it my self but i have very little time with owning a shop. do you think this could be the cause of my orgional viabration problem? thanks.
Old 01-19-2007, 06:22 PM   #6 (permalink)
kccats
On a stand can you see anything?
Old 01-20-2007, 12:10 AM   #7 (permalink)
stickyicky
everything looks normal... no grinding... when turning the secondary with no belt on... turns fine again with no grinding... drive shaft bearings are good.. had nine bearings and sliders replaced ($250 I think i paid a little much) still no change, im baffeled. thanks for all good help guys!
Old 01-20-2007, 09:41 AM   #8 (permalink)
kccats
The only thing I can think of from loading on the trailer is did you hit or run over something? Could the drive axle be slightly bent? You could likly see that on a stand and rev, the track center might go in and out a 1/8"? Don't know but if the drive bearings are to be changed you could roll it and look,the same with the jack shaft!
Old 01-20-2007, 02:48 PM   #9 (permalink)
Check your engine mounts, rev it and see if the engine moves a lot.
Old 01-20-2007, 04:23 PM   #10 (permalink)
stickyicky
didnt hit or run over anything.... loaded very slow, I was thinking the drive axle as well... but the mechanic said it was fine. in regards to the engine mounts, i had an exaust leak at the flange so i wraped it with a fiberglass wrap and put the spings back on... after i did i was thinking that there should be some play there. motor moves a bit but nothing crazy. all this help is great... thanks
Old 01-21-2007, 06:54 AM   #11 (permalink)
There are 3 things that turn, the primary clutch, secondary clutch/jackshaft, and the driveshaft for the track. I'd say your track driveshaft is bent. Put the back of the sled up on a stand. start it and get the track turning. Check the shaft that the secondary turns, then look under the sled and watch the track driveshaft. One of them is wobbling.
Old 01-21-2007, 03:58 PM   #12 (permalink)
stickyicky
if the drive shaft is bent... what does it cost for a new one?
is it difficult to replace?
Old 01-21-2007, 04:00 PM   #13 (permalink)
stickyicky
and would this be caused by loading it on a trailer?
Old 01-21-2007, 06:31 PM   #14 (permalink)
The shaft is relatively cheap, changing it is a *****.....
Old 01-22-2007, 08:58 AM   #15 (permalink)
kccats
Did you take the chain case apart? I had an exciter that I wish I would have? The hole case exploded! But I wonder if just one link could have broke?
Old 01-22-2007, 10:09 AM   #16 (permalink)
Check the drive cogs for any chunks missing or any splits in them.
Old 01-22-2007, 11:39 AM   #17 (permalink)
stickyicky
all this help is appreciated... im going tear it down tonight and ill let you know what i find.... the mechanic said he checked over everything but i will now do it again to double check.
Old 01-22-2007, 06:53 PM   #18 (permalink)
kccats
Could you have a warped rotor?
Old 01-28-2007, 07:25 PM   #19 (permalink)
stickyicky
ok guys took it all apart.... didnt notice anything, put it back together and no viabration. now i dont know if this is normal but when on a stand spinning the track it has a ticking sound almost as if the track is rubbing somewhere. also i noticed the back of the tunnel gets hot and always steams... i thought it may be normal to melt the build up of snow, is it? thanks
Old 01-28-2007, 07:34 PM   #20 (permalink)
Try to find out what the ticking is. The steam is normal.
