Grab it for that price, they are awsome older sleds. The only way to fit a 2in paddle is to remove and bypass the front heat exchanger and to drop from the 8tooth to 7 tooth drivers. That is not optimal because you can ratchet the drivers being smaller and it gives a bad aproach angle. The best thing to do other than spending 700 to roll the chaincase, just run a 1.5, if you want to run 1.75 and keep a good aproach angle then remove and bypass front heat exchanger. They are a good durable sled. Some would bog from powder ingestion in deep powder but you just need to close the hood slot when you are in powder. If you put a 136 1.5 or 1.75 on you will be able to keep up with that xlt. I ride with a guy with an 87 exciter with 136 1.5 and a guy with an xlt600, that exciter can out do that xlt every time, but keep in mind that the rider is the big difference.
