Ok before I cause myself more work than needed I just figured I would ask... Is there an an easy way to align the headlight? Or is it all in the steering? It points to the right a tad. Just thought I would ask before I starting tearing the light assembly apart to find out that it has to be done in the steering..
Well I found out what the problem was. The Caulk was just the icing on the cake. Pretty much the whole headlight mount is jacked, missing screws, and such. So I bent everything back into shape and spent $.87 at the hardware store for new screws... The caulk that was glued on there cost more than that.... Sometimes I just have to wonder.
