12-17-2006, 11:07 PM
saskatchewan sledder
freeplay on steering
i have a quick question. does anyone know how to get rid of freeplay on the steering of a '93 venture gt 480? i would take it apart and figure out but i don't have loads of time and it would be quicker and easier if someone told me. anyone know how to?
Whatever is written above is just my $.02
My family puts the "fun" back in dysFUNctional.
whoever said nothing is impossible, never tried slamming a revolving door
12-18-2006, 04:28 AM
Check the tierod ends the spindle bushings and any loose bolts in the stearing column.
12-18-2006, 07:15 AM
You need to check the steering system over to see where the free play actually is. We can't tell you to change part X.
12-18-2006, 06:41 PM
thanks ill check it over tonight. probably something stupid like a small loose bolt like you said.
12-18-2006, 08:03 PM
I had a lot of play, and the rod ends were all tight. My Cats have composite bushings, on the steering shaft, top and bottom. I replaced the bushings, and it's all tightened up now. It's best to look at an exploded parts view if you can. Then identify the wear areas, and take a look at yours in those spots.
2000 440 Panther
1980 Jag 3000 F/C
12-18-2006, 08:56 PM
thanks ill find the problem. its such a pain doing anything on these sleds tho because they're so compacte, you have to take everything apart to get to some things. does mean a much smaller sled tho.
12-18-2006, 10:03 PM
Originally Posted by badbrad
...its such a pain doing anything on these sleds tho because they're so compacte, you have to take everything apart to get to some things. ...
Just look at a NEW sled. Everything is so crowded up front that you can forget about working on them! It's crazy!!! I'll take an older one, any day.
2000 440 Panther
1980 Jag 3000 F/C
12-18-2006, 10:14 PM
ya i know specially the yammi's tho they even started crowding them when my sled was new. yet i can look at other newer sleds and they are far more open, really depends on brand.
12-18-2006, 10:57 PM
J. DRISCOLL
Enjoy working on them 2 Strokes. My 4 stroke is tight as all hell. There is now breathing room at all. But then again i havent had any problems wiht it. And then again this year who knows if i will, we dont have any snow to create problems hahaha
12-19-2006, 08:31 AM
I was thinking Sno Pro and Rev. Both of them have NO spare room under the hoods. I had a number of choices of where I wanted to put my extra oil holder in my ZL. Could have put a couple of them in there easily. With the new designs, you'd barely be able to fit an oil CAP in there, forget about a quart bottle holder.
And speaking of oil caps... oh, I better not go there!
2000 440 Panther
1980 Jag 3000 F/C
12-19-2006, 08:58 AM
sundaypuncher 503
i like my 1997 mxz 670! there's tons of room to move around while woring on the engine etc...
THE BEST THINGS IN LIFE GO BRAAAAAP!!!!!!
12-19-2006, 10:48 PM
yah, polaris and and late 90's and earlier skidoo's seem a lot more spacy.
12-20-2006, 08:34 AM
The ZR and ZL chassis has enough room to stuff a few cats in there...
Hmmmm... not a bad idea! I could get a hot-dogger, and have Chinese on my long rides.  Now where'd my neighbor's two cats go??? Here kitty kitty...
2000 440 Panther
1980 Jag 3000 F/C
12-21-2006, 11:18 PM
06 M7 162
the M7 still has some room in ther and the way the side panels flip up works verry nice
chinese hay that sounds good I think thers room for Garfield in here .
12-22-2006, 11:01 PM
though i do like how the sides flip down to see the clutches, on the one side, and the chaincase and brakes and that stuff on other side.
