Old 12-10-2006, 01:10 AM   #1 (permalink)
Arctic_Cat661
Help Me!
Hey i have a 97 Vmax 600 xt....i am quite happy with the sled its top end is great i can get it doing 110mph+ on the spedo....it as some mods but nothing major...my big concern is how can i get the clutch to engage sooner...when i punch it well moving it take a few seconds to really grab on and go and from a dead stop i cannot lift the skis and i know there is more then enough power to do it......any ways to help me lift the skis would realy help THANX
Arctic_Cat661 is offline   Reply With Quote
Old 12-10-2006, 01:45 AM   #2 (permalink)
At what RPM is it engaging now?
Old 12-10-2006, 07:34 AM   #3 (permalink)
Could be the clutch system binding up.
Old 12-10-2006, 08:24 AM   #4 (permalink)
kccats
could the trak just spin. Do you need a better trak or studs?
Old 12-10-2006, 11:20 AM   #5 (permalink)
IndianRvrShiver
IndianRvrShiver's Avatar
New belt would help greatly!
You can reduce ski pessure by loosening the limiter straps, but be aware this will effect the steering performance, as well!
Old 12-10-2006, 12:04 PM   #6 (permalink)
Arctic_Cat661
yes the track does spin but this is part of my problem i just put a brand new inch adn 1/4 on it and i beleive that the clutch is engaging around 3700rmp
Old 12-10-2006, 01:49 PM   #7 (permalink)
kccats
That sounds low perhaps yor spring is getting weak. 4000 to 4500 would engage better. A 1 1/4 is a deep track, could yhe belt be slipping?
Old 12-11-2006, 10:34 AM   #8 (permalink)
Arctic_Cat661
sorry it actually engages at 4700rpm oops
Old 12-11-2006, 10:39 AM   #9 (permalink)
Thoroughly clean the clutches and make sure that your belt is not worn.
Old 12-11-2006, 02:53 PM   #10 (permalink)
kccats
So what's the problem? If you're still spining the track maybe stud it? Maybe loosen the limiter strap?
Old 12-11-2006, 06:22 PM   #11 (permalink)
Arctic_Cat661
yah but how do i loosen the limiter strap
Old 12-11-2006, 07:39 PM   #12 (permalink)
kccats
Near the front of the track there should be 2 leather or ruber straps from the slid rail going up to the upper fixed pivot with a long bolt and nylock nut. Spray the threads with PB Blaster or Liquid wrench then loose the same amount each. this should put more tension on the front of the track and less on the skis, if not put more spring tension on front track shock. You could loosen the tension on the rear shock and the sled would squat more. But if you are doing this just to look kool be carefull, you have no control with the skis in the air, and it's hard to see too
Old 12-12-2006, 04:02 PM   #13 (permalink)
Arctic_Cat661
great thnk you i am going to try that tonight and i will post my results yah finally out of the whole first with any chance
Old 12-14-2006, 07:25 PM   #14 (permalink)
Arctic_Cat661
i am having trouble locating my limiter straps.... .....if you can explain it better that would help or if you got pictures that would also be great thax
Old 12-14-2006, 09:03 PM   #15 (permalink)
kccats
There should be some kind of strap that keeps the front of the track up. Put the sled on a stand (something safe)
look within the first foot of the track, there should be one on each side, at the top there should be a long eye bolt and nut. Loosen the nut evenly! about 2 full turns?
Old 12-14-2006, 09:07 PM   #16 (permalink)
litle_Jon
Lynx rider!!!
litle_Jon's Avatar
soft suspension can kill the wheelie in a start
also might want to clean upp your clutch
Lynx enduro 600 '01
litle_Jon is offline   Reply With Quote
Old 12-14-2006, 09:29 PM   #17 (permalink)
PolarisINDY500
SENIOR MEMBER
PolarisINDY500's Avatar
track spin is all relative to how fast you "gun it"...any sled can spin the track when you goose it from a dead stop...even with studs
i think you need to play with your clutch if you want a quicker start. check the belt too.
The Original Logo ->
Old 12-15-2006, 04:05 PM   #18 (permalink)
Arctic_Cat661
thak you fellas i will try it tonight
