1988 Phazer Compression ??
The other day I went to change plugs on the wifes 88 Phazer and the right plug was cold and the left plug was warm. I did a compression check and the right cylinder was 120 lbs and the left cylinder was 150 lbs. Do I have a bad cylinder ?? or is the difference ok ? I have lots of spark on both plugs.
