Found two problems last week and today.
I brought my sled in last week to a local repair shop:
Motorsports Plus
Jeff Fisher
651-455-5657 (St. Paul, MN)
He knew right away what the problem was; the engine was running too rich due to a design "flaw", for a lack of a better word. It seems that carb intakes on the yamaha's twins get clogged with the dust from the belts. He says that usually after about 2000 miles or so it's normal for the performance and gas milage to take a dive (From the dust clogging the intakes). The shop owner was a complete genius with what he did with my sled; it's like I have a brand new sled. Among the other things he did to check out my sled, he took the carbs out and cleaned the rubber dust build up out of the intakes. He said that it was really bad (I've got about 3k miles on it). His price was VERY reasonable to fix this; under $125. He also took out my clutch and verified everything was ok, the track alignment, track condition, and a few other things. He was very complete with his examination and very reasonable with his price.
I did also notice today on my other sled that the clutch is engaging at about 5000 rpms. I remember the previous owner mentioning about changing out a spring in the clutch. This is causing some gas problems on that sled when travelling slow for an extended period of time.
I drove up to N. Mn today from the twin cities to try it out and I was astonished with the change. Actually up by you Dano. We took the state trail just north of Duluth then got on 302 and stopped over at a bar about 14 miles up. Excellent riding in that area, I'm going to explore it more. I really just wanted to try my sled out quick. (2.5 hours up, 5 hours of sledding, then 2.5 hours back)
