I'd check a few things,make sure you have the correct belt,is the brake stuck,is the track too tight.Try lifting the rear of the machine and see where it engages then.Check with your manual for track tension and measure to see how it is.
Also I'd check with the dealer and find out if someone changed the spring in your primary clutch.This will make your machine engage at different RPM. Get them to check and tell you what colour spring it should have and compare.
Just a few ideas where to start.
Let us know what you find out.
let it snow!!!
