02-06-2006, 09:26 PM
Backfire/hesitation In Engine
IVE GOT A 89 SRV THAT HAS BEEN BACKFIRING AND HESITATING.ON START UP WHEN YOU PULL THROTTLE IT HAS A TENDECY TO DIE AND SOMETIMES BACKFIRE.I CLEANED CARB,AND CHANGE COIL BUT PROBLEM STILL THERE.IT WILL IDLE FINE ALL DAY UNTIL YOU OPEN THROTTLE.ANY INFO WOULD BE APRECIATED....THANKS...WAYDE/NFLD.
02-07-2006, 08:42 AM
New plugs!!
02-07-2006, 02:04 PM
Ditch Banger
my jag did pretty much the same thing...turned out it was a crack fuel line going to the carb. looked pretty cool at night seeing a fireball come out of the exhaust under the sled lol..
theres no replacement for displacement!
Ramsey Bay Snowmobile Club - Weyakwin Lake
http://www.ramseybaysnow.com/
97' ZR 580 EFI w/ 1 5/8" track -->3000KM
98' ZL 500-->6000KM
98' Jag 34000-->5000KM
02-07-2006, 05:00 PM
Backfiring=lean. Check the fuel system again....
02-07-2006, 06:23 PM
i was told backfiring was because it was too much gas... when we poured gas into the cylinder of some kids really old motoski we poured too much in wich caused it to backfire...
"slidin rear, back window, so it's an easy reach to where my cooler keeps 'em iced down cold"
truck- 1998 chevy 1500 extended cab 4X4 Z71 package fully loaded 5.7L vortec
sled- 1989 Polaris Indy 500 Special (blue clutch spring) FOR SALE!!!!!
2007 Honda CRF 230
2003 Honda CRF 230
02-08-2006, 12:09 AM
new plugs
02-09-2006, 09:26 PM
my line coming from the tank is full of little bubbles.just wondering if this is okay...thanks...wayde/nfld
02-09-2006, 09:36 PM
Is it coming out of the fuel pump that way too?
02-10-2006, 11:31 AM
Not a good thing! Inspect the check valve/filter inside the tank as well as the hose. Make sure all your fuel lines are in good shape (no cracks/splits) and also ensure that all connections are tight. When you see air bubbles moving in your fuel lines, there is something amiss!
02-10-2006, 03:41 PM
CHECK THE T.O.R.S. SWITCH-UNPLUG THE 2 WIRES GOING TO THE CARB FROM THE HARNESS THEN PLUG THE HARNESS ENDS BACK TOGETHER-THIS BYPASSES THE SAFETY SWITCH. HOPE THIS HELPS.
I'M OK. YOU'RE OK. WE'RE ALL OK.
02-20-2006, 03:02 PM
have the same problem with my 89 SRV,i bypassed the saftey switch and it does work. im guessing this was a problem with many srv's.
~Nate
02-20-2006, 06:53 PM
Newfoundland RULES
broken reed valves????
"Ya no's what a Yammie is don't ya bye'
Lard Tunderin Jasus bye', tis a skidoo with a Yamaha sticker on da side of er' "
Download buddiwasisname, da yammie, you won't be disappointed
02-20-2006, 09:07 PM
do you really think its a broken reed valve.im from newfie as well (gander bay).this machine has cost my soul this winter.
02-20-2006, 10:46 PM
I am the Walrus
my sled backfires when the plugs foul.
My Pics
1999 Arctic Cat ZL 440
1994 SkiDoo Mach 1 583
1995 Honda CR 125R
1982 Camaro w/ 355
02-21-2006, 03:26 AM
Newfoundland RULES
I would try disabling the TORS for sure first since it is so easy to do. After reading your post again probably not reeds since it will idle fine all day but if TORS doesn't fix it worth taking a look at the reeds, should be able to spy on them without diassembly with a mirror and lite.
I had to diable the TORS on my Venture first when I bought it. Got it from an older gentleman here who said that machine backfired like that for years. One day after getting it, did some research in the forums and Voila, fixed.
My father is from FOGO!
