could be old gas or bad plugs or coil or spark plug wires reversed, water in the gas mabey carb problem
does it have any power, my QT50's exhuast port was cloged with carbon and did almost the same as you are expeciencing with your srv, but the srv would probally blow the carbon out on its own, seeing that is a biggger motor
