Old 01-21-2006, 04:49 PM   #1 (permalink)
88Yama
88Yama's Avatar
88Exciter - Running FAST
Putting an '88 Eciter back on the snow (Father-son project).
Got my hands on a used PSI Racing exhaust from a bone-yard (Exhaust was missing when I got the sled). Cleaned out carbs (varnished beyond belief!). Now when I start it up, it revs up to redline unless I keep the choke/starter all the way "on".
I've turned the idle control out, almost to the point of falling out
and checked the pilot air screw (5/8 turn out as spec'd).
Not sure what size jets/needles I'm running or should be, or if that is even an issue here. Seems like a pilot jet issue?
I'm a bit new to this Carburetor stuff (I like to work of fuel injected CARS!-)
Any help/pointers would be greatly appreciated!
88Yama is offline   Reply With Quote
Old 01-21-2006, 09:27 PM   #2 (permalink)
Are the throttle slides dropping completely down onto the stops, or is the throttle cable too tight? There should be around 1/8 inch of play in the throttle lever before it starts to move the slides.
Old 01-21-2006, 10:25 PM   #3 (permalink)
88Yama
88Yama's Avatar
Good question. I made sure they were lined up when I put them in. Is there a way to tell without taking the carbs (back) out to see the slides move?
Old 01-21-2006, 11:55 PM   #4 (permalink)
mx and sled 41
mx and sled 41's Avatar
remove the air box, and put your hand into the carb and doo it by feel.
"slidin rear, back window, so it's an easy reach to where my cooler keeps 'em iced down cold"
truck- 1998 chevy 1500 extended cab 4X4 Z71 package fully loaded 5.7L vortec
sled- 1989 Polaris Indy 500 Special (blue clutch spring) FOR SALE!!!!!
2007 Honda CRF 230
2003 Honda CRF 230
mx and sled 41 is offline   Reply With Quote
Old 01-22-2006, 10:28 AM   #5 (permalink)
letitsnow
I am the Walrus
letitsnow's Avatar
you will have to rejet with the pipe.
My Pics
1999 Arctic Cat ZL 440
1994 SkiDoo Mach 1 583
1995 Honda CR 125R
1982 Camaro w/ 355
Old 01-22-2006, 04:34 PM   #6 (permalink)
88Yama
88Yama's Avatar
ALL RIGHT!!!! Thanks for all the advise folks! SEG, you called it.
The throttle cable adjusters had been backed WAY OUT.
Dunno why I didn't think of that. (Made for an interesting ride when it first started earlier this week.... That's another story. Suffice it to say: Memo to me, set the break and/or remove the belt when starting a sled with freshly cleaned carbs. You never know...)
ANYWAY, I ran them in until the cable housing stopped following. Turns out there is a ring right at the top of the adjuster, on the cable housing. Turning it in just a bit more reveals about 1/8 inch of the cable housing past the line... Cable is slack... (Makes me wonder if the previous owner tried to compensate for the grunge clogging up the carbs by just cranking them back.)
It's now running at a normal speed, holding around 1-2K rpms. Idle can now be controled by the Idle Control Screws (WHO KNEW!?)
It's a bit "smokey". I let it run for about 5 minutes or so.
Then checked the plugs. Center electrode is UPS brown and just
a bit of black oil around the outer ring... Not bad?
I hink I now need to balance the carbs. But before I go there...
How do I find out what size jets I should be running?
Thanks again, everyone!
Old 01-22-2006, 04:49 PM   #7 (permalink)
Main jet size is #320. There were a few optional ones offered, though. The spark plug sounds perfect. I'd keep it as is. Make sure the oiler is working properly also. Is the fuel old? Old fuel will smoke badly. Glad I could help!
Old 01-23-2006, 02:34 PM   #8 (permalink)
Bad idea, the engine can "run away" and you will not be able to shut it off. the belt can help keep theis from happening and you can use the brake to slow it down so it will shut off.
Also there are warnings posted on the engine compartment against this.
Old 01-25-2006, 11:40 PM   #9 (permalink)
FxsX24
PitXsnocross.com
Re: Memo to me, set the break and/or remove the belt when starting a sled with freshly cl
what is "running away"
FxsX24 is offline   Reply With Quote
Old 01-25-2006, 11:48 PM   #10 (permalink)
SergeantDHall
SergeantDHall's Avatar
88 Yama,
Yamaha Exciters 87-90 ran Mukuni 38mm Roundslide powerjet carbs, and they were jetted from the factory for sea level as follows:
Left Carb - 320 main jet, Powerjet - 160
Right Carb - 320 main jet, Powerjet - 200
All the Exciters from Yamaha were jetted rich, or fat, whatever terminology you are accustomed to using, but depending on your elevation, there was alot you could do to really liven up these machines. I have two Exciters, and have played extensively with the carbs, because I could not find anyone who could give me a reasonable answer on how to properly jet the carbs for performance or mileage at the elevation I ride, and through trial and error (never burnt down either machine's motor) was able to determine what the proper jetting was for a given elevation.
It will probably surprise you, but for the altitude I ride at, which is 5500-8000 feet, I have my carbs jetted as follows:
Left Carb - 280 main Jet, Powerjet - 140
Right Carb - 280 main Jet, Powerjet -145
Now, this is still just a tad bit rich from my plug readings, but the power is fantastic. One other thing to note, is factory gear ratio's are roughly about 10% to high. A factory stock gear case was a 17/31, if I am correct, and I have mind geared down to 15/31. Granted I have given up about 9 to 10 MPH on top end, but the machine is an animal for hill climbing and in deep powder, corner to corner is awesome and I can keep up with most 700's and a few stock 800's, besides this, I'm to old to going much over 80 to 85 MPH anyway, it scares the hell out of me!
Its not how fast you go, but how good you look!
SergeantDHall is offline   Reply With Quote
