Old 01-02-2006, 07:35 AM   #1 (permalink)
NY Snowman
NY Snowman's Avatar
2005 Yamaha TORS
Does anyone know how to dissamble the TORS feature on a new 2005 RS? The manual says it's an easy step but I disagree. Mine isn't running right sometimes backfiring, flashing code 84. I was told just to disconnect and it will run fine. A safety feature not needed. Thank you. The dealer will be the next stop.
NY Snowman is offline   Reply With Quote
Old 01-02-2006, 09:33 AM   #2 (permalink)
SnowRida
Runnin Against The Wind!
SnowRida's Avatar
TORS is your throttle over ride system. If your throttle sticks, your engine will shut down. There should be wires aroung the carb area that you could unplug. But why would you want to do this? Sounds like a defect. Is the sled still under warrenty? I would get it fixed. It's there for a reason. I'd check it out I I were you and get it fixed. Just my .02.
SnowRida
Yamaha V-Max
02 MXZ 600
97 Polaris Indy Trail Touring
Old 01-02-2006, 09:58 AM   #3 (permalink)
NY Snowman
NY Snowman's Avatar
Thanks for .02 snowrida. Yes it's still under warranty. The manual says it's under the handlebar pad. I am bringing it to dealer just trying easy fix first. P.S. If the throttle sticks i could just turn the key off. Thanks
Old 01-02-2006, 04:02 PM   #4 (permalink)
FxsX24
PitXsnocross.com
not if you come off the sled, my throttle was sticking on my srv, im gonna get a tether just in case i come off and it get stuck open
NYSNOMAN where from ny are you
FxsX24 is offline   Reply With Quote
Old 01-02-2006, 06:51 PM   #5 (permalink)
NY Snowman
NY Snowman's Avatar
Upstate NY The tether is a good idea! Thanks fxsX24
Old 01-02-2006, 09:03 PM   #6 (permalink)
FxsX24
PitXsnocross.com
did you go to the pit x race on new years eve?
Old 01-02-2006, 10:48 PM   #7 (permalink)
ROBERTMOOKIE
ROBERTMOOKIE's Avatar
TORS
PLEASE LET ME KNOW HOW DEALER FIXES THE CODE 84 TORS THING I HAVE THE SAME TROUBLE.
ROBERTMOOKIE is offline   Reply With Quote
Old 01-03-2006, 11:28 AM   #8 (permalink)
case sensitive
There was a TSB about the TORS. Check with your dealer if your sled applies. I know both our Vectors had TORS issues last year, that were taken care of as a result of the TSB.
I'm also from Upstate NY, an hour north of Amsterdam.
case sensitive is offline   Reply With Quote
Old 01-06-2006, 04:55 PM   #9 (permalink)
NY Snowman
NY Snowman's Avatar
I read the owners manual and disconnected the TORS. Very easy to do . Haven't road it much yet , just a couple of miles, we'll see, dealer if I have to. I really don't want the TORS working at all, that's what the kill switch is for!!!
Old 01-07-2006, 05:55 AM   #10 (permalink)
SnowRida
SnowRida's Avatar
Remember, it's there for a reason.
SnowRida
Yamaha V-Max
02 MXZ 600
