my srv will crawl on one cylinder, check the belt , if the sled has a comet on it and the engine will rev up past 5000 easily(i say 5000 because it should move by then even if the belt is shot) then the spider on the comet may have cracked, if it has cracked , DONT just get the spider (unless the comet is fairly new) get the whole clutch (the reason i say this is you might run into more problems with an older clucth and a new spider
