2002 Yamaha Venture TOS problem
I just got the sled out for the season but I have a problem (I think) with the throttle override system. Maybe someone can confirm this.
From a stand still I give it gas and once it reaches 3000 RPM the cylinders cut out. The engine will stay at 3000 regardless of throttle position. The symptoms are the same if I hold in the TOS and give it gas. It's a intermittant problem but a pain none the less.
Is this a glitch with this type of system on the Yamaha's? Could it be a bad contact somewhere?
