Can't figure out what is wrong with the drivetrain
I'm wondering if anybody can figure out what may be wrong with my buddies sled. He has a 2000 venture 500. When he starts rolling it makes a clunking noise in the drivetrain. Like something is catching then slipping again and again. He can get it up to high speed where it doesn't seem as bad. I think the problem is somewhere on the drive sprockets shaft that spins the track.
We tried to diagnose it. This is what we did: We took the belt off and noticed that his secondary clutch had a lot of play. We could turn by hand at least 30 to 40 degrees. Then we started to try and track down where the play was coming from. Took the secondary off and there is no play between that and the shaft. No play between the shaft and the top gear in the chaincase. No play in the chain, or from top gear to bottom gear. We didnt take the drive sprockets shaft out yet.
Does anybody know where it could be slipping.
Sorry for the lengthy post
